Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Sat Aug 23, 2008 1:41 pm
That transmission in your diesel should be the same one found on the gas engine versions of the 720. That includes the 4x4 and 2WD versions.
The biggest difference in the transmission's is going to be the tail shaft length. The 4x4 trannys have a shorter tail shaft than their 2WD cousins because of the position of the divorced transfer case. The bell housing and starter bolt patterns are all the same.
I plucked 5 speed from a 2WD, 1979 720 and installed it in my 1985 4x4 720. All I had to do was get the factory drive shaft shortened 2 inches. The splines on the output shaft (tailshaft) were the same too.
