hotshot240sx »
https://forums.nicoclub.com/hotshot240sx-u2435.html
Tue Aug 17, 2004 3:00 pm
so your not getting fuel past or before the filter then? i would check the fuel pressure. you may be pumping fuel, but maybe not enough pressure. i would also check to make sure your lines are on correct from the pump not crossed. and if you installed a fuel filter make shure its not on backwards, i know these questions seem like common sense and im not trying to insult you or anything. but we need to know this information to help you further.
