heyman421 »
https://forums.nicoclub.com/heyman421-u167116.html
Thu Mar 17, 2011 10:05 am
Has anyone had any luck replacing a corroded tail light socket on their 720?
My rear driver's side turn signal has one of the lead wires broken flush with the assembly.
I tried to dig the wire out enough to solder a new wire on, but it's shoddy at best.
I took the whole assembly off the truck, but the sockets appear to be glued/permanently attached to the tail light assembly rather than riveted/screwed/pressed in.
I'm wondering if anyone has had any luck replacing a single socket on these tail lights, or if a junkyard replacement is my only option?
New after market lights are still being made for the 84+ vertical style assemblies, but not the horizontals.
