81 280zx problems
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
babyfat45
Car: 1981 280zx
project z
so i just bought my first z :) its a 81 280zx non turbo but i have some problems its hard to start, to start it u have to pump the gas petal a few time and my be it might start lol im wondering why here was else is wrong
slipping clutch
egr valve is dented
theres a short somewhere cause my volt meter always stays at 12 volts even when the car is off lol
gas meter dont work
speedo needle is broken
ok heres what i replaced
fuel pump and fuel filter
cap and roter
spark plugs and spark plug wires
im stuck can any one help? :gotme
sawyer's720
Car: 1984 Datsun 720
well about the volt meter, on my 76 it always stays on, im pretty sure that's how it's supposed to be. As for the hard starting maybe Evil can help ya.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
slipping clutch gonna go out on a limb and say maybe it needs a clutch??
erg gone, well you can leave it gone or put it back to stock if you prefer, just makes intake or exhaust removal more difficult
the voltmeter, I honetly don't recall if it stays on but if it doesn't go up when running then something is definitely wrong, alt, voltage regulator (which should be internal on your car) wiring??
gas "meter", and speedo, maybe a new cluster is a good idea, ebay is full of used z parts then there are local clubs, larger used parts suppliers like zbarn et
as for difficulty starting, are you pumping the pedal before or while cranking, you realize the car is injected so pumping before cranking does nothing, and pumping while cranking you could flood the engine, first thing I'd check is fuel presure, put a gauge inline and see if it holds pressure overnight, if nto then the seal in the fpr si bad, replace ti and it should hold pressure and bea easier to start
babyfat45
Car: 1981 280zx
project z
lol ya i know it needs a clutch :p but ya it when im cranking the moter and pushing the petal it will some times start
evildky
06 Nissan 350Z GT
pedal=
petal=
also motor, not moter
now that we're clear on those issues
pushing the pedal while cranking is generally a bad idea on a fuel injected car, do the fuel pressure test i described and let us know what you find
Return to “Datsun Z Forum”
