Booztd 3 wrote:It is likely your starter motor has increased in resistance which is going to cause an increase in amperage as well. Bench testing is not necessarily a valid test in this scenario as you're not putting any load on the starter motor.
i would like to point out I = V/R So increasing your resistance without increasing your volrage would lower your draw. What i would do to test it is, with the car off, jump the little wire (switch) on the starter to +12V, and see if it blows the fuse, if it does, your starter is shorting someware. Check for frayed wires. if you can't find any it's the starter itself. Drawing 80A for 5 seconds will make it get HOT, so you should be able to tell. Also doing this in the dark will allow you to see if anything is sparking. If something is sparking, that's what is bad.
If you don't blow the fuse, it's something else. but at least you have a starting point.
