dicknixon »
https://forums.nicoclub.com/dicknixon-u163879.html
Wed Aug 11, 2010 7:51 pm
I recently got a 1980 720 under the impression that it would run with a little work.... well it has the hood vents the carb and the old lady i bought it froms son, left the air cleaner off and rain got in it and for however long it was open siezed the engine, i thought i had everything good to go after i got it and i could hear the starter try, but it wouldnt turn over, so i tried to turn the engine over with a breaker bar and just ended up turning the nut even after repeated treatments with pb blaster in the cylinders , so i pulled the carb off it was rusted shut and there my adventure began....
I have been looking for a relatively easy and definately cheap swap, i saw a guy had two 2.4s from an older z with a dual webber carbs for a good price, it is the straight six version its a l24 and if it is it should bolt right up to the l20 trans etc except the mounts will need to be relocated and an electric fan set up , that is all i should need to do for a swap like a l2.6 and l2.8 in a 720 right?
I have also been considering if my head is still good on the l20 i could do a lz swap with the head of the 2.0 and the rest from the 22, i have read alot on here, and there are soo many different ways to do every one thing, but like i said i will have to pull the old motor to see what is good on it for the latter swap.
and for a real backwoods way.... this is simply to cure my curiosity, but someone said something about beating the pistons down with a block of wood and running it like that... would it even run, im sure it would run like total crap if it did and circulate crap through the system and eventually die.. like i said just for my curiosity, it doesnt make sense to me
sorry for the long post but any info would greatly be appreciated.
Thanks.
