WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sat May 24, 2008 6:08 am
It's not so much the volume of the air being moved, but the temperature of the air itself once it's compressed. This is an example only because I have no idea what the real rpms would be, but here goes.
The T4 compressor would only have to spin at 20,000 rpm to make 8 psi of boost where the T25 would have to spin at 35,000 rpm. So the efficiency of the compressor for the T25 has reached it's maximum where the T4 is just starting it's day. As an example, the older Porsche's used bigger turbo's because they had no room for an intercooler. By using the bigger turbo, they had more lag, but the compressed air charge was cool enough to not require an intercooler. So they accepted the lag but were able to create more power in the end.
It's all about how much work is required for something to move something else. That's just general physics though.
The T3/TO4 is a far better turbo then the T25.
WD
