8 Gauge Speaker Wire through firewall - 1995 240SX
nowayou7
Ive got a 1995 240SX SEI need to where to run my 8 gauge wire through the firewall in order to connect to the battery, that is, without drilling a hole. Where would I drill a safe whole anyway? Any help would be appreciated. Thanks.
red240ne
Car: mmm...donuts
i think all 240's are the same. there is a hole that isn't even used on the passenger side floorboard. lift up the carpet and you'll see it.
Lepchitz1
Car: Cars, and LESBIANS!!!
you can poke a hole through the boot on the drivers side where the wiring goes to the fuse box...thats where i did min...it was easy
R240NA
Passenger side, in the fenderwell, behind the liner, you'll find a grommet, about sized for 4 gauge. It dumps out right above the ECU. That's where my MAF harness runs now, makes it invisible.
Syntax360
Car: 1986 Nissan 300ZX Turbo
i looked for about 5 minutes for an unused hole and gave up and just drilled a hole through the passenger floor and sealed the other side w/ silicone. It popped out in a spot and all is well :-)
nowayou7
Actually i just drilled a hole driver side and all is well. Thnx
BabyboyDeLa240
Car: Cars, Girls, and Money
Lost_To_A_K-Car wrote:Unused? Dude, that's a speed hole. Don't obstruct it with anything other than carpet.
I was just wondering what is a speed whole? And what is it used for? I have Zero gauge running from my left side(driver side) but i took it in to a shop for them to install. I am not sure what they did if they even drilled a whole or cut something.
