8:1 FMU/stock injectors or hacked MAF/370s for 6 psi non intercooled?
turtl631
Car: S14
Whihc basic engine management would you choose for this setup and why? I jsut want about 200 whp as a stepping stone to a better setup with JWT ECU, 50 lb, etc. This would be with a t3/t4 50 trim. I won't be turning up the boost past 6 psi until i can get an intercooler and good fuel setup. Oh, base timign would be retarded by probably 3 or 4 degrees in both setups.
Structure240sx
i was running an 8:1 fmu for months at 9psi with no problems. easier and prolly safer than the hacked mafs.
a good option might be to go with an safc and the 370's now. so later when you have the jwt you can fine tune it with the safc
