Mudgen »
https://forums.nicoclub.com/mudgen-u178605.html
Thu May 19, 2011 12:51 pm
Yes, I think that's also what SteveTheTech has said, but seriously, there's a procedure starting on p.258 of the TM section of the 2010 sedan FSM for changing it, and it's labeled "Periodic Maintenance". Have a look. Here's how it starts:
PERIODIC MAINTENANCE
A/T FLUID
Changing INFOID:0000000005623959
CAUTION:
• Use only Genuine NISSAN Matic S ATF. Never mix with other ATF.
• Using ATF other than Genuine NISSAN Matic S ATF will cause deterioration in driveability and A/T
durability, and may damage the A/T, which is not covered by the INFINITI new vehicle limited warranty.
• When filling ATF, be careful not to scatter heat generating parts such as exhaust.
