79` 280ZX 2+2
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
79`280ZX
Car: -1981 Datsun 280ZX 2+2 - 1968 Datsun Cedric PL130
I`m Building my 79` 280ZX into an Turbo Version.I need Help Finding out What 280ZXT between 81-83 I should take the Turbo and Pistons from?
My father has an 75` 260Z with an L28ET Engine in.!And it`s the greatest car I have ever been in
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
your best bet is with a complete donor car, or at least the entire engine, harness and ecu
the blocks don't really matter and really neither does the pistons, they are all cast it's just a matter of compression ratio, if you have 8:1 compression ratio or lower your fine to boost it, also the 82-83 are the ideal donors as they use the opticle distributor and the 81 uses an external crank angle sensor, also the 82-83's were available with the more desirable T-5 transmission
just be sure you get the fuel pump, complete wiring harness, ECU, MAF and the plumbing
other than that you can hang the turbo exhaust manifold on any L6 head so long as you haven't build a high compression engine
your 79 is likely and N42 or F54 block, with flat tops pistons and a P79 head and about a 7.9 compression ratio (if memory serves)
if your compression ratio is higher and you want to retain your block and head for some reason you can replace your headgasket with a 2 mil Nismo copper head gaasket that will lower your compression ratio by about .5:1
79`280ZX
Thanks alot.My dad know`s a guy that restores Old Z`s and my dad got him to build a new Turbo Engine.It`s a L28ET but the Stock exhaust and the Turbocharger has been changed.The Engine has 312BHP and runs like a Beast.We only payed like $60 for it and it`s a completly Restored.When we get the 5spd manual Transmission back we are going to install it.
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
post some pics!
79`280ZX
Only have one picture of the Engine.Where the Engine is in the original car.It`s been Rebuilt.
evildky
06 Nissan 350Z GT
thats not a turbo engine, wrong intake, valve cover and no J-pipe, all these things can easily be changed but it looks like a stock 79 N/A engine
79`280ZX
evildky wrote:thats not a turbo engine, wrong intake, valve cover and no J-pipe, all these things can easily be changed but it looks like a stock 79 N/A engine
Sorry That is The Stock Engine from my 280ZXnot the Turbo Engine Dont have a picture of the L28ET
79`280ZX
I have a crazy friend that thinks he knows more about Nissan/Datsun then me.He says that If I am going to install an Twin Turbo V6 fromthe 300ZX I should convert it to a Single Turbo couse he thinks that I get more power out of it I dont think he knows Spit about Nissan/Datsun
winez31
Car: 1993 s13 ka24de
well you won't necessarly get more power but fitment will be easier, but i always say the more the marier
79`280ZX
winez31 wrote:well you won't necessarly get more power but fitment will be easier, but i always say the more the marier
yeah but he says that with One Turbo you get more Compresion and if you can fit a V8 in a 240Z you can fit a V6 in a 280ZX so that`s not a problem.
winez31
you will faster spool from two. he doesnt understand the fact its a v6 not an inline its not easy to convert to one turbo. if u do u'll need new manifolds made a crossover pipe made. its to many headaches.
79`280ZX
winez31 wrote:you will faster spool from two. he doesnt understand the fact its a v6 not an inline its not easy to convert to one turbo. if u do u'll need new manifolds made a crossover pipe made. its to many headaches.
yeah and it`s a waste of money and time to Convert to a Single Turbo to.
evildky
06 Nissan 350Z GT
I thought you were planning a L28ET swap?now you want to do a VG30DETT swap? thats a much more involved much more expensive swap not really wort t unless you just have to have it
79`280ZX
evildky wrote:I thought you were planning a L28ET swap?now you want to do a VG30DETT swap? thats a much more involved much more expensive swap not really wort t unless you just have to have it
no I`m going to swap to L28ET we where just talking about the VG30DETT.I called a guy yesterday and he is going to build me an 316BHP L28ET.so In a week I have my L28ET I`ll post some pictures when I get it
79`280ZX
The Best Dream ever!!Driving around In a 1970 240Z L28ET powered and Listening to Whitesnake!!what can be bether?
Return to “Datsun Z Forum”
