'79 280Z which clutch question
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
RagingPanda
Car: 78' 280Z
I have a 79 5speed on my 280Z. Do I just buy this replacing clutch kit? http://cgi.ebay.com/ebaymotors...ories
Is there a differ between a 2 seater and 2+2? Is the flywheel diameter larger on the 2+2? What about for the turbo motor? I just want to make sure before I buy the wrong thing. Thanks guys
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the 2+2 and turbo use the larger clutch disk and flywheel surface, if you have the stock 2 seat flywheel from a 70-83 then you get the smaller 225mm clutch, if you run the flywheel from a 2+2 or turbo 79-83 then you need the larger 240mm clutch, if you wanted to upgrade to a stronger clutch an easy thing to so is simply run flywheel and clutch from a 2+2 or turbo model, they have a much higher holding capacity
RagingPanda
Car: 78' 280Z
cool, I didn't know you can just do that. Since the L28 motor and transmission are pretty much the same on 280z to 280zx can I use the energy transmission bushing for 78 280z on 79 280ZX? Do you know where I can find an aftermarket transmission mount on top of your head? I'm just being overly paranoid for no reason.
evildky
06 Nissan 350Z GT
trans mounts are all the same from 70-83
Return to “Datsun Z Forum”
