thrice »
https://forums.nicoclub.com/thrice-u121734.html
Wed Dec 10, 2008 5:46 am
OK, so at the start.
There was a popping noise.At the connection from pipe to manifold, everytime it would pop, i would see a little ploom of smoke come out from that connection.I took it apart, and the gasket was pretty much gone (down to just about the 2 rings)So put in a new gasket with copper spray, and i'm not seeing anything comeing out of that connection.But now, when it pops, it sends a small ploom of smoke out the back of the tail pipe. Also i don't really think its smoke, as its cold outside and it goes away after the car warms up.the 280z is a 1978 with stock fuel injection.I hear the popping noise when:I give it some gas, and then left off all the way. When the rpms drop to idle speed, it sends a pop out, but it doesn't happen everytime, only about half the time.Ill be checking the timing over the next day or two.
