Hello All-
I was just given a one-owner 1977 620 regular cab/short bed. It runs great and I'm taking care of some "deferred maintenance" things. The right front drum brake was virtually locked up, so I loosened it up, but I need some explanation of the directions.
The '78 Service Manual I downloaded here:
http://www.olddatsuns.com/data...8.pdf
says on page BR-2 (page 349 of the PDF) "lightly tap adjuster housing and move it forward" in the directions for adjusting the rear drum brakes (front discs in '78, of course) before turning the cog wheel adjuster. I assume this causes the ratchet/pawl that engages the wheel to retract and allow the adjuster cog wheel to be easily moved.
Problem is, I can't for the life of me figure out what they mean by "adjuster housing." My setup looks identical to the illustration. What I'm seeing is what appears to be a spring clip a bit like a stretched horseshoe that is retaining something that looks like a square bolt head. I tried tapping this backward and forward but nothing seems to move. I'm concerned because I can turn the adjuster wheel in either direction without much resistance, so it seems like the ratchet isn't engaging.
The previous owner says he had problems from day one with the brakes constantly needing manual adjustment, for what it's worth.
I'd pull the wheel but I don't have a dry place to work.
Please help me, O Sages of the Busted Knuckles!
Thanks.
