Larz »
https://forums.nicoclub.com/larz-u216291.html
Mon Feb 24, 2014 1:23 pm
When I bought my M35, the mileage was in the 60s. I bought it from CarMax as it was the only M with bourbon leather I could find. I took it to my local Infniti dealer for an oil / filter change so I would know for sure I was starting with new instead of hoping that CarMax changed it as they claimed. My infiniti service guy found service records in the system, but no record of transmission, cooling system, or diff service.
During that first year, one by one, I had all the fluids changed. Some will tell you that if the transmission is past 50k miles and you can't be sure it was ever flushed, just do a drain and refill. However, I saw no point in adding clean fluid to dirty parts, a dirty pan, and a dirty magnet. The place where I get my tires and brakes does flushes so I had them flush it, clean the pan and the magnet, and re-fill it. They also drained and refilled the diff (RWD). I had NO issues with shifting, smoothness, or timing before the service and have had no issues after.
I had the coolant system flushed and re-filled with a new radiator cap, and I had the brake fluid replaced at the last brake job. I replaced the power steering fluid myself the old school way: I modified one of Fetucini's turkey basters with tubing at the end, siphoned the PS fluid out the cold resevoir, then refilled it to the cold level with new Nissan PS fluid. I repeated that every few days and I eventually added about 3 quarts of new fluid. Now the fluid is a clear, deep cherry colour and is super slick. The old fluid was not nearly as slick, had tiny particles like fine dust in it, and was a deep brownish red.
