neverlift wrote:yeah the fuse is IN place, I have plenty of them for now. I wont try with my battery till the resistance is gone.
I have it narrowed down some, when tapping the relays behind the fuse box, in the drivers kick panel.
I'm thinking its just a relay thats stuck open, if thats possible?
A relay stuck open wont cause a short. Im not really sure what you are doing. You have the battery connected and the fuse in and you are wiggling wires to try to blow fuse?
have you tried reconnecting various things to see if fuse blows? the alternator is the most obvious source of the short.
you can also look for voltage drop to find short. obviously, battery is connected when you test for dc volts.
