BigBump »
https://forums.nicoclub.com/bigbump-u17225.html
Tue Aug 01, 2006 8:13 am
Did you set your decel-air settings?
Easy to do, helps out a ton with bumper poo and fouled plugs.
Start car cold.
Go to decel air, and set it as low as it will go and still maintain idle (usually around 1.5ish) Set 2nd point .75 to 1.2 higher (2.2-2.7) and you're done.
Also, do you have a wideband? I'll bet you're running super rich as it goes into boost, also causing the foul, so spend the 290 bucks on the aem gauge type wideband, and toy with it.
Or spend the 1k on the PFC with datalogit and be done with tuning woes.
