740cc Injectors on Stock Manifold and fuel rail.
Nicksemianiw
Car: JDM 89 Silvia K's
Can i run 740cc injectors on the stock intake manifold and stock fuel rail, and if i need a new fuel rail will that fit on the stock manifold depending on if its top feed or side feed? Or will i need a new manifold all togeather?
Thanks,
Nick.
red_sir
You can run side feed 740cc injectors with the stock fuel rail. Or, a cheaper option is buy a top feed fuel rail and use top feed 740cc injectors. Either way, you can keep the stock manifold.
BaliLover
Nismo or Tomei 740ccs. Drop in fitment, no need to even change wires. You can get them for around $500 a set.
Nicksemianiw
Also is there any other intake manifolds out there other then the greddy one for SR20DETs that wont be like 2 G lol
RMiller
Car: BBQing
There's a knockoff of the greddy and the greddy isn't 2g's, it's under 500.
Nismo_Freak
Car: 89 Nissan 240SX
red_sir wrote:You can run side feed 740cc injectors with the stock fuel rail. Or, a cheaper option is buy a top feed fuel rail and use top feed 740cc injectors. Either way, you can keep the stock manifold.
Top feeds aren't cheaper.
By the time you buy a rail, injectors, connectors, and a FPR setup you've spent the same if not more. The only benefit is that you can move up in injector size at a later time using cheaper injectors, and/or you can use a better FPR.
red_sir
I paid: New 65lb/hr injectors - $243 ($10 more for 75lb/hr's)New top feed fuel rail off ebay (works with stock FPR) - $80 Used connectors - $5Total - $328 shipped
Those are everyday prices too, not any special groupbuy/sale. You'll have a hard time finding new side feed's for that price.
Nicksemianiw
I know how much the
RMiller wrote:There's a knockoff of the greddy and the greddy isn't 2g's, it's under 500.
I know how much the greddy manifold is but i am saying i have seen other ones polished out there for more then 2000 USD
