How heavy is the stock L6 ?Olderthanme wrote:The VH45DE isn't THAT much heavier than the stock IRON block L6...
I'm pretty damn sure that the longer engine spreads more weigh to the front on a 260z.Robstar wrote:G'day mates!
I've recently purchased a 74 260z which will be undergoing a bit of stripdown, rust repair, etc..
I've always loved V8's and I could blab on about why I like the VH45DE in specific so I'll cut right to the chase.
I want to put it into a 260z, a few mates at work and some 'Mechanical Engineering' student-friends, are saying it's a really bad idea, that it apparently '****s up' the weight distribution of the car. That I should just put a RB26DETT in it or something. (By the way, I'm in no way saying this lightly, I understand just how expensive these engines can get)
My question is, should I take this with a grain of salt? For such a huge project, I think not! Please, enlighten me with as much knowledge as you can as to the truths behind their quotes.
As a daily driver, as a car to take on hill climbs with other 240-260'z and etc. Is the extra weight that much of an issue? I don't understand what I haven't done already, so I'd very much like to know the pro's and con's of putting this engine in the car.
An if the pro's weigh (pun intended) against con's more, then you'll be seeing a project thread quite shortly. Please, looking forward to any and all responses.
- Robert
Yes of course me contemplating a VH45DE in an S13 with 5 speed attesa 4wd. I have experienced quite few of those mouths. I've learned to just let them talk.Robstar wrote:
Has anyone ever had experiences like this? Constructive criticism is nice, but there is a fine line in my opinion. I think if I said this was a straight-6, he wouldn't of been so hell bent on damning the engine (which he clearly doesn't know anything about) to hell.
Okay enough ranting lol, probably not the place.
But what good will that do you if you're taking internals out it can't be for a good reason either way if you're retrofitting this V8 you better be prepared for this.evildky wrote:I can have an L6 stripped to a short block in a car with hand tools only in about 30 minutes, try that with a VH
or try to get 80k on a stock motor at stock boost levels? thats the problem the latest LS! swapped FD is having, he's already rebuild the engine once, he's the orsioonal owner and he's got 80k miles one it, so he decided after driving an LS swapped FD that he like the feeling of torqueT45 wrote:The wankel is one of the coolest engines ever made. Period. More cars should come with it if you ask me. It's very efficient and has great durability. That is....until you give one to a gear head and he tries to cram 82 lbs of boost in it, then the engine is considered junk to everyone.
