720 using s13 springs.
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
a10wagon
Car: 80 510 wagon
have any of you guys tried using s13 rear springs on the front of a 720.i have heard that s13 rear springs are the same diameter.if any one has tried it please confirm if this is true or not.thanks
PEZi
That is not even possible without some modification considering the 720 is a torsion bar setup... That being said... no.
a10wagon
Car: 80 510 wagon
o ok.my bad.i just figured the 720 was coil spring because alot of 720 mechanical parts fit on a 80 510 wagon. so i just figured they were coil spring also.srry about that
PEZi
Not a problem man. Learn something everyday, right?
Return to “Datsun 720”
