720 tow capacity
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
twenty
Car: Kingcab 720
i have an 84 kingcab with a l20b 5 speed. any one know what the maximum tow capacity is?
Thanks
Aven
Car: 84 720 Kingcab
I've looked for an online owners manual and came up empty.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
From the '81 manual:Never exceed value for trailer with brakes is 2000lbs, 1000lbs for trailers without brakes. Maximum gross combined weight shouldn't exceed 5000lbs (5400lbs for 4wd models).
Max tongue load is 10% of trailer weight, and should be considered part of cargo load and gross axle weight rating.
Max cargo payload (not trailer) is 1100 pounds for all models, and rear max gross axle weight is 2400 pounds.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
The information given by captainzeros is for all combinations, that is engine and gearbox. Whether its the L20B, Z24 or J16 as in my case. It just means the bigger the engine the faster you will move.
Return to “Datsun 720”
