Nate720 wrote:
Not sure if im doing this the right way
With Photobucket, try to just click on the thumbnail photo you want to put in your reply and then right click on the full size image and pick "copy image" and then paste it in the reply.
If that doesn't work then it's a lot harder to explain, I refer to photobucket as photolame as it used to be easy to use, there is a chain link above the photo in a row of other icons, click on the chain link, then copy the IMG code and paste it in the reply.
Well it worked both ways for me, the top way is the easiest, good luck, if you can somehow get a good code in your reply, I can likely use that to post the photo for you, but I need a good link.
