720 MOTOR SWAPS
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
zedman280
Car: 78 datsun 280z (turbo) / 1990 nissan 300zx twin turbo / 1982 datsun 720 4x4
hey guys, I'm in the same boat as a lot of you out there. Have heard of possible swaps, but can't find any technical detailed HOW-TO write ups.
IS there anyone out there with some write ups on common motor swaps, ie KA24.... etc
anything would be greatly appreciated ! cheers
78 datsun 280z turbo82 datsun 720 king cab 4x4 (stock, 400,000 kms +)90 nissan 300zx twin turbo
nis720
Car: 86' Nissan 720 truck / 06' Silverado truck
Here's my writeup on a my KA swap. The only thing I did different was the motor mounts. I relocated the frame mounts, but I have been told it can be done by simply modifying the driver motor mount bracket.
http://www.cardomain.com/ride/28173/7
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Did you used the same gas tank as when it was a carb'd motor?
I read you should swap tank due to baffling or something.
I really want to do this swap.
nis720
breadbox wrote:Did you used the same gas tank as when it was a carb'd motor?
Yeah... I kept the original gas tank and simply upgraded the fuel pump with the Walbro 255. I heard that too about the baffles or running on low fuel but I haven't had any issues regarding the fuel so far.... I just fill up before it gets below 1/4.
breadbox
89 Koop
84 720 4x4KC
Oh so the issue is with a low tank. Thanx.
2kredz3
Car: 1984 Nissan 720
I have been thinking of a SR20det motor swap since the prices are good on complete engines and trans. but i have not seen anyone do it yet.
PEZi
maybe this is my problem... feel free to throw in any suggestions
my motor is still carbed and i do indeed use the truck for autocross.... when the tank gets below 3/4 and i pull hard left corners there is some fuel cut out... but only turning left. also... to keep from sputtering randomly and losing power i have to fill up at a half tank and as long as i do everything else is fine
zedman280
Well done, thanks very much for the link !!
Cheers
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
You stall on hard cornering? The easy solution is to use a surge tank. It's cylindrical in-shape and connects directly to the fuel supply. It has a line which goes to the carb and a return connection. Its primarily used in after market sport applications when a fuel cell is not used and is normal for fuel injected cars associated with steep assent or decent roads. Of late the fuel injected cars come with the surge tank installed in the fuel tank and the return line returns the fuel to this catchment in the tank instead of directly to the main fuel tank.
Return to “Datsun 720”
