Would love to post some pics of my freebee 720 but cant figure it out, guess thats why I have a wife! anyway my 1980 720 is having issues, the truck has been sitting since 2002 and I am now putting it back on the road. So far I have soaked the carb overnight and reassembled, drained the tank and put in fresh fuel, changed the fuel filter. The prevoius owner took all the emissions off and converted to a manual choke, when everything was ready I fired it up and had a dead miss, so i ran a compression test, 120 on 3 cylinders and 115 on the other so no real problems there. New plugs seamed to fix that problem, now it runs good for about 25 miles the it starts to load up the center 2 plugs, outer 2 seem to burn clean and the fuel mileage is way off, full tank of fuel in about 100 miles. Since I have had the carb back off 2 times thinking I sucked up some debris but clean as a whistle. Set the timing and rechecked it a few times but same problem. Today another set of plugs 1 heat range hotter hopeing that might have some positive effect, also changed the plug wires the other day and same problem, the vacuum line for the distributor seems good and has an effect when disconnected to set the timing. I also ran it for a while without the air filter or the top of the air cleaner assembly thinking it might be choking off the air supply but same problem. I am thinking I have a vacuum leak, possibly in the manifold but that should cause a lean condition? Anybody have a good idea?
