720 hesitates
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
hauntingurcoma
Car: 86 720
10 of 85 720 z24 carbed starts right up idles good when i let out clutch it stumbles wants to die put the clutch in and idles fine again.hesitates through out all gears but clears up at about 3500 rpm.Ran great until a week ago.changed plugs,fuel filter.any ideas??
seang
Car: Ford Fiesta ST
It sounds like you might have a vacuum leak somewhere. Where that is I haven't a clue and you would have to go through all the hoses to find it. Something might be wrong with your carb, too. If there is, get a Weber. They are cheap used, and even new they are about the same as the stock s***-tachi. My old shop manual said that the carbed z24's had distributor problems, but I can't testify to that because I had a Fuel Injected z24.
hauntingurcoma
Car: 86 720
ok ill start with the hoses ty
Supererogator
Car: 1980 Datsun 720 King Cab
I second the hoses. I had one come off before I replaced them all because it was ...well, olld. My truck did very similar stuff. Not a z motor, but....
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I third the hoses. but if you have a slight leak its best to just replace it hose by hose. finding leaks itsn't as easy as they make it sound.
hauntingurcoma
Car: 86 720
i will do that. also does anyone know which coil is exhaust and intake? how do u tell?
hauntingurcoma
Car: 86 720
i fixed some hoses and did cap and rotor.its better running just sounds like a miss at idle now
breadbox
89 Koop
84 720 4x4KC
Have you looked at your valves yet?
jump
Car: 1986 nissan 720 pu
do ya'll know if we can just eliiminate the whole vacuum get-up and plug a hole or six and have a better running vehicle...???
or not?
are the guys that race these things pulling the vacuum system out or what are they doing to hot rod the z24?
Supererogator
It is my understanding that Japanese vehicles of this age, are very reliant on the vacuum system. Best to leave it in. I also know that many people have disconnected some of the emissions control stuff, and this has been done to mine, but I fixed some of it up when I replaced the hoses, and this has made it a bit more consistent.
You might also look into the timing, plugs, plug wires, and firing order. These can all be issues as well.
hauntingurcoma
Car: 86 720
plugs are new,ive double checked firing order according to the book,havent done wires yet but look in good condition.any certain brand of wires msd accel,i work at a toyota dealer in parts and our sister store is a nissan dealer should i get factory wires.they ordered the fuel filter in the pump for me still waiting for it.Can i just loosen and turn dist. to adjust timing like old chevys?
breadbox
89 Koop
84 720 4x4KC
I go with the rule of thumb that people use round me. Unless you are using and aftermarket ignition system.
Jap motors get NGK
Ger motors get bosch
US motors get whatever.
seang
Car: Ford Fiesta ST
Just for good measure, check that the coils are grounded out enough. My roomate had a z20 in a 200sx that ran like ish when the circuit failed.
Supererogator
Being a Ford guy, I cannot confirm nor deny that your distributer timing adjustment is about the same, but, my mom's 46 Chevy and my 80 Datsun are not so different. My mustang is similar too, so I would say, yes, loosen screw, plug vacuum advance, and get out your timing light.
BTW-I like Autolite for old US cars....but whatever works...may just be the Ford in me.
hauntingurcoma
Car: 86 720
changed fuel pump filter,think i got all vac lines,noticed the butterfly on carb is always open hot,cold am,pm shouldnt that be closed at some point? tried turning dist but didnt help.
Supererogator
Mine seems to be open a lot more than my old Ford did, but it does close from time to time....I have not played with it because it seems happy. I would clean out the carb and make sure all the parts are moving and not damaged. My factory manual for my '80 has lots of notes about cleaning in this kind of situation. Again, not a z engine, but it might be the next step.
2kredz3
Car: 1984 Nissan 720
hauntingurcoma wrote:10 of 85 720 z24 carbed starts right up idles good when i let out clutch it stumbles wants to die put the clutch in and idles fine again.hesitates through out all gears but clears up at about 3500 rpm.Ran great until a week ago.changed plugs,fuel filter.any ideas??
ah yes, check the vacuum lines that go to the passenger side fender where you will find the vacuum switches for clutch release switch and trans in gear switch. what these do is cut fuel when activated under off throttle conditions to save gas and decrease emissions. if the hoeses look good buy a haynes manual and it will tell you how to test those to make sure they are working. if they are not working right then you will have this problem.
Return to “Datsun 720”
