720 Heater stopped working
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
supra_rulz
Car: Toyota Supra MK3 1JZ
Datsun 720
Few days ago i tried to start the truck up after letting it sit for about a week or two and starts up great. only problem is the heater wouldn't turn on. checked the fuses inside the driver side and all looked good. took apart the control unit and tested the ground on the unit, looks good. next i turned the key to on and checked voltage. reads zero across all settings. i haven't checked the blower because if i'm reading the wiring diagram right (first time ever using one. didnt think physics would ever haunt me like this) if the control unit isnt getting any voltage, than the blower wouldnt either. so now i'm stuck. whats the flaw in my diagnostics?
second question:
the cable to the temp control snapped so i traced it back and its not connected to anything. i tried autozone's manual but couldnt understand the picture. so help with that also.
thanks.
supra_rulz
Datsun 720
ok, so the longer i stare at this diagram the more i'm starting to think that i'm reading it backwards. going to go test the motor and try replacing that to complete the circuit.
supra_rulz
Datsun 720
never mind, the culprit was the 4-pin connector from the controller to the wiring.
still dont know where that loop thing connects to though so help for that is appreciated.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I haven't messed with my heater yet, but it should be pretty evident where is connects just figuring out how the door is supposed to move.
supra_rulz
Datsun 720
just to make sure, i'm not talking about the line that redirects the air, its the one that adjust the temp. and if so, i have no idea what door your talking about. lol
Return to “Datsun 720”
