720 diff
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
720-kcab
Car: 86 720 kingcab
Hi guys just wondering if any one could help me out with a bit of info on wat vehicles have a diff that i could use to replace the one in my 86 720 kingcab 5spd manual l18 flatdeck any help will be much appreciated
thanks
Josh
seang
Car: Ford Fiesta ST
cukali
i dont think that link is of any use to him.
You will need to stay with a 720 2wd diff. I suggest going with a whole axle replacement since it is easier to find axles then gears for our 720s lol
You can take just about any axle from any nissan and put into your truck. Some are easier than others. If you like LSD then grab an axle from a late 80s pathfinder and it pretty much bolts right in. Staying stock by grabbing another 720 axle will also work. A little cutting/welding may be required but its very simple stuff.
You can pick up a whole axle for about $150.00. Your gears are about $150.00 new. I can swap out an axle faster than I can shim gears so you see the best route?
Return to “Datsun 720”
