mcmmech »
https://forums.nicoclub.com/mcmmech-u147796.html
Tue Nov 17, 2009 3:02 am
I have a '84 Nissan 720 311K miles and a brake problem. At low speeds, steep down hills and the rain the rear brakes lock up, even with extremely steady pressure on the pedal. I have replaced all components (master cylinder, front calipers, rear wheel cylinders, and I even swapped the NLSV valve with one from the junk yard) still no change.
UPDATE: I have disks on the front, drums on the rear. I looked at the system and the front operates SEPARATELY from the rear. (one line comes out of the master cylinder, splits and goes to each of the front wheels: another comes off, goes towards the rear, through the NLSV valve then splits and goes to each of the rear wheels)....one thing i haven't tried is new drums.......i'll put a dial indicator on 'em...see what the deal is...
Thanks for all the suggestions.....keep em comin'!
Modified by mcmmech at 5:09 AM 11/18/2009
