MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Mon Apr 25, 2005 1:09 pm
Here's the deal:
I have a JWT ECU programmed for 370 cc injectors, S14 MAFS, MT, etc....to get it retuned it'd take probably 6 weeks, and my engine will be done a lot sooner than that...and I can't just swap a stock ECU in there because of the fuel injectors, and I don't feel like going through the hassle of reinstalling stock fuel injectors and then some RRFPR just to break the engine in...
Enthalpy's ECU's are out of the question because apparently there's a 3-4 month wait on a part he needs to tune S14 ECU's (convenient, huh?)
So I figured I'd have much better luck just finding someone with a JWT ECU already tuned for 50 lb or 72 lb/hr fuel injectors and a larger MAFS, and then install this with new injectors and sell my existing setup to re-coup much of the cost. The problem is, JWT ECU's tuned for an S14 MT with 50 lb injectors and a cobra MAFS are few and far between....It seems that the ones tuned for 72 lb injectors are far more prevalent.
I found someone selling a JWT ECU tuned for 72 lb injectors and the MSD 72 lb injectors themselves for $600 (not that bad of a deal, but not that good either considering klattr1 was selling this same ECU, the same injectors AND a MAFS for this price a while back...).
My question is, would 72 lb/hour fuel injectors be overkill for my goals? I'm planning on running around 330 or so whp on a fully built engine..I can't see myself EVER wanting more power, nor is it feasible/practicle/safe to have so much power on the street with street tires. I know 50 lb fuel injectors are said to be good past 350 whp, which is why i wanted them...but are 72 lb/hr fuel injectors necessarily worse if I'm not going for the huge numbers one can achieve with such injectors? I know Jeff @ cip motorsports is running the 72 lb program for a 16 psi, 340 whp tune...
Here's my concern: people using a JWT ECU tuned for 72 lb fuel injectors are going for much bigger numbers (400+ whp) than I am, meaning the ECU would be tuned even MORE conservatively than the 50 lb tune, in both fuel map and timing, meaning for the amount of power I want to run, the tune would be far too conservative and rich (correc tme if I'm wrong here). The engine is being fully built with forged 9:1 wiseco pistons and all that good stuff but that doesn't mean I want to get the absolute limit out of it and go looking for 400 whp, because I know I'll be plenty satisfied with anything around 330. Also, I'm severely low on cash. Rebuilding an engine costs a LOT of money, as does upgrading the fuel system. So I am not going to have the $250 to fork over for a S-AFC II, at least not for a pretty long time (I'll pretty much be in debt the whole summer). All that I have to "tune" is an adjustable fuel pressure regulator, and I'd rather not use tha to tune, because lowering the base fuel pressure can adversely affect the spray pattern of the injectors.
Also, I take it 72 lb fuel injectors would be even MORE of a ***** to have pass emissions with compared to 50 lb fuel injectors...I already passed emissions with my KA-T and 370 cc fuel injectors....
Next question: What's the main difference between high and low impedance fuel injectors, besides, obviously, the impedance? I know the 50 lb/hr fuel injectors are high impedance, and the 72 lb/hours are low-impedance. What else is needed to make the 72 injectors work, besides the injector harnesses? What's the difference in regards to passing emissions?
Final question: Does JWT tune an ECU going in a car with 8.5:1 compression pistons differently than a car with 9:1 compression and differently in a car with 9.5:1 compression? I would hope they do because there's a substantial difference between 8.5:1 and 9.5:1 when it comes to being safe and preventing detonation. But, JWT's site is absolutely terrible and has pretty much NO information.
Let me know your thoughts...
-Marc
