70k high milege?
Plankton
Car: nissan s13
Hey fellows, i just received s13 CA front clip it has roughly 70k on it, after doing several searches i got the assumption 70k is pretty high(please correct me if im wrong). Unfortunatelyi cant touch until i finish moving, for the time being i was wondering if a few of you guys could give me a heads up of what to expect that will break.
Thanks.
dareo
Car: 1993 Q45, 1989 240sx
The mileage could be a good thing if it was regularly driven and maintained. But most people here myself included woudl recommend a tear down, inspection, and rebuild as needed.
NeedCAforS13
Car: CA swapped S13 coupe
70k miles or km's? I wouldn't consider either of them too high... considering the age of them at least.
Sean
Plankton
Car: nissan s13
Its 70k miles, and i also noticed that the clip had a few aftermarket parts on it , that were taking off before i received the clip. Also at this point I was looking to tackle the suspension, but i don’t want blow my money away, sense there is a possibility a rebuild could be necessary. But i really do appreciate you guys input on this, and looking forward to more.
boost_boy
Plankton wrote:Hey fellows, i just received s13 CA front clip it has roughly 70k on it, after doing several searches i got the assumption 70k is pretty high(please correct me if im wrong). Unfortunatelyi cant touch until i finish moving, for the time being i was wondering if a few of you guys could give me a heads up of what to expect that will break.
Thanks.
Most importers offer a 30-day warranty on their clips/engine sets less a warranty on the turbo, which gets no warranty. If you wanna do something to be safe, inspect the timing belt. Other than that, I would suggest installing the engine set in the car and enjoying it. Makes no sense to tear down an engine that you've already spent money on, that probably doesn't need a tear-down an way. My advice, get your money's worth before you go dumping more money.
Dee
Plankton
Car: nissan s13
Well, thats one way to look at it you right on that. This car is my daily driver so in a way i would like it to be as realiable as posible, so at this point i'm thinking a tear down might be a pretty good idea.
8ggalant
Car: nissan cefiro
so the speedo read over 140k kilometers...id say thats high mileage
