Then neither will addding a cooler.elwesso wrote:... however 1000BTU really wont matter much either way...
So did you use the B&M 70268 for you Active car?GQ Jay wrote:one thing you might consider is that a 3/4 inch thick will fit in the gap between the condensor and the radiator.since mine is an active, that is about the only place--hence why i put it there. but even on a std car, i think that will give you a very clean installation.stacked plate, of course.
I once heard someone say "Go Big or Go Home" ... wonder who that was?!?! .elwesso wrote:any cooler is better than stock......
HOWEVER you dont want to cool the transmission toomuch.. thats why i recommend the smaller cooler to people who live in places where it gets cold.Rex wrote:I once heard someone say "Go Big or Go Home" ... wonder who that was?!?! .
Okay so then I'll get the 70268 and mount it between the condenser and radiator.GQ Jay wrote:one thing you might consider is that a 3/4 inch thick will fit in the gap between the condensor and the radiator.since mine is an active, that is about the only place--hence why i put it there. but even on a std car, i think that will give you a very clean installation.stacked plate, of course.
Did you bypass the filter and/or the stock cooler?ceningolmo wrote:I bought the smaller of the two for my active... and, it seems to be working fine.
I did them in series because we have winters in TX. I have a 70268 on one car and 70264 on others. Look in Owner's Rides for the pictures.dannym wrote:Did you bypass the filter and/or the stock cooler?
There's also a thread somewhere by a guy that switched to full Mobil 1 synth transmission fluid and saw a 5 degree drop (had transmission temp gauge, IIRC). But I'm sure that was comparing old OEM fluid to Mobil1 Synth.maxnix wrote:I did them in series because we have winters in TX. I have a 70268 on one car and 70264 on others. Look in Owner's Rides for the pictures.
I need to find that site again where these drag guys gained another .1-.2 seconds in the ¼ mile by reducing ATF temperature from 176° F to 140° F.
