reggiegsd »
https://forums.nicoclub.com/reggiegsd-u144.html
Sat Mar 15, 2003 9:08 am
The info is close with some modifications.
"70 to 73 was 240zs with 2.4 liter carbureted sohc 12v L24, only 2 seater available."
This is true. 70 through 72 used SU carbs with only minor differences during the tree year run. This is the pure Zcar engine. Not as tourquey as some of the later ones, but it revs like crazy. It desperately needs a 5-speed transmission which was only available in Europe. 73 went to Hitachi carbs, very unsatisfactory, swap them out.
"74 to 75 was 260z with 2.6 liter carbureted sohc 12v L26,and a 2+2 became available."
The 260Z was a 74 only in the US. Same bore with more stroke. Same bad carbs. The engine didn't rev as easily as the earlier engine but there is nothing wrong with it.
The 74 260Z came in two body types. I'm not talking 2 seat and 4 seaters, I'm talking the early 240Z and the later 280Z body structures. The first half of 74 used the 73 240Z body and the last half of 74 used the 75 and later 280Z body. They look very similar except for the bumpers, but internally the later cars had more stiffeners and thicker metal. Much heavier. It is kind of like the difference between a 93 and a 94 Q. They look the same, sort of, but are very different on the inside.
"76 to 78 was 280z with 2.8 liter fuel injected sohc 12v L28e,2+2 available."
Make that 75 to 78.
"when did a/c become available?"
All years. Dealer added option from 70 to 74. The compressor was a York reciprocating unit and vibrated allot. Refit one of the later rotary types.
"Power steering?"
Not until the 79 or 80 280ZX. And it will NOT backfit. The only time you need it is with very wide tires.
"I hear the 280s are more rigid because the frame rails go all the way to the back strut towers but added weight. what year did this start and how much weight did it add?"
Alot more to it than that. No, the frame rails didn't go to the rear strut towers. Figure an early 240 will weigh 2250 and a late 280 will weigh 2800.
"Were there any other changes year to year that affect performance? "
Almost every part is interchangeable between 240s and 280s. Some body parts are different. Drive train parts from the 79 through 83 280ZX can be used to. My favorite drive train is the 83 NA engine, transmission, and a Subaru R160 limited slip rear in a 73 240Z or an early 74 260Z body. Still light weight, small bumpers still fit, and solid reliable 200hp with fuel injection.
Strangely enough, that is exactly the setup I have now.
