Bubba1 wrote:Good stuff ^. I'm surprised Jesda ignored the Japanese offerings because if you're interested in reliability, they are above the German and American offerings.
The #1 large premium car for long-term dependability has consistently been the 2006+ Cadillac DTS. GM has, essentially, had two decades to work out the bugs and it shows. There's also a limited number of gadgets outside of heated/cooled seats, a V8, a 4-speed auto, sat nav, XM, HIDs, and Magneride (available only in the DTS Platinum). The most common issues are xenon lamps that can blip out.
http://gmauthority.com/blog/2011/03/j-d ... ium-sedan/
The Lexus LS will never leave you stranded but more
can go wrong simply because of the larger quantity of gadgets and features. I've done a few cross-country trips in LS400s and LS430s and the LS400 is significantly more enjoyable to drive while the 430 has more passenger-friendly features like reclining/massaging/heated/cooled rear seats and a rear fridge, a nice place to store cans of Pelligrino. The 430's Mark Levinson sound system is
pathetic for what it costs and the expensive speakers blow quite frequently. The 430's well-aged navigation system isn't so great either, as I've experienced first hand.
Watch out for air suspension on the 430 -- it doesn't do much for ride quality but it costs an arm and leg to repair. Unless you really want the totally decked out reclining and massaging rear seat, rear fridge, and built-in curtains, go for a lesser-optioned 430 with the standard suspension and Pioneer sound system. The base audio is arguably as pleasant as some premium sound systems.
The telescoping steering on the LS430 is known to go bad so once you find a desirable position, try to set it and leave it. Pull the fuse to keep people (like your kids who are driving-age) from futzing with it and wearing it out. Play with the mechanism and check for noise and grinding.
The rear parking sensors can go bad on occasion.
The last 430 I sold had a bad folding mirror mechanism too, a fairly common issue on these cars. Easy to fix (replace the whole mirror) but very annoying. I suggest disabling the folding feature.
The most common and expensive LS430 problem is with fuel fillers that stop when the tank is only half full. You have to lower the entire fuel tank assembly to have the neck replaced. It's a PAIN to repair yourself and ANNOYING to live with. Lexus will only cover it if you're still under warranty, so Google around for the TSB and hand it to your mechanic.
If you get a 430 with radar cruise, make
sure it works. That is NOT a cheap fix. The sensor is COSTLY.
In park or neutral, rev the engine a few times (slowly) to check for light misfires at specific points in the rev range. Walk away if it acts up. It could be anything from a MAF to a coil pack (most common reason) to head gaskets (less common, but possible).
I know more than I care to about these fancy Toyotas and need to displace this knowledge with something more interesting. Nothing causes panties to dry up faster at a bar than when Jesda gets hammered and starts talking Lexuses.
