z6hatchboy »
https://forums.nicoclub.com/z6hatchboy-u126912.html
Wed Jul 29, 2009 2:52 pm
thanks for the help. My battery is on charge so what i done it unhooked the charge cable from the alt and then ohms that end (not touching anything) with the body and still pulled the 7 ohms. Then did tested the alt for the heck of it with the body and it was 0 which is right. Now, the charge wire has may 5 inches before it goes in the loom and re-appears at my junction block. So im guessing its skinned or something leading to a short inside the loom? Im thinking about running so good gauge amp wire in its place from the alt to my junction block now to by-pass all of that. Do you think that will be alright? the factory charge wire goes straight from the alt to the battery doesnt it?
