JedCoop »
https://forums.nicoclub.com/jedcoop-u11491.html
Sat Jan 06, 2007 10:06 pm
I changed the #7 injector on my G50 without removing the plenum. Not sure it was worth the hassle, though, to get to the one hard-to-get screw holding down the injector. If I were to do it again I would just remove the plenum bolts but not totally remove and disconnect it much like goody94Q suggests. But you don't need that much more room to get to the screws and pop the #7 injector out. So I doubt you need to remove the TB and IAC, but you may need to disconnect the EGR to get enough sidewards movement.
A little depends on your plenum gaskets too. I have changed mine, so they were not so old, and felt sure they would still reseal well. If your car still has the originals, the old plenum gaskets may work fine, but I haven't tried that. Also buy them before you start the job from Scottsdale... the local dealer charge me $10 for one when I accidentally damaged it, and needed a replacement quick.
Good luck.
