NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu May 26, 2005 5:15 pm
there is a .9 degree difference between the 2. Caster gives you steerability your car will likely pull left with the right being so far forward. Basically on a more dramatic scale if you were to look at your tires standing from one side of the car and there was a perfectly straight line across you car through both sides the right front tire would be slightly forward of the left front tire. Caster is like a motor cylces rack on the forks. choppers are hella positive, street bikes are still positive but at a more managable level. Choppers are very hard to make quick turns on to avoid collisions where crotch rockets are more agile and can manover quickly. Caster on cars is pretty much the same way. I dont know the spec on your car but I would think anything more then .5 degrees is to much, I personnaly try to shoot for .2 difference.
