this is how i did it...MiddMackAttack wrote:How do you get 6x9's to fit in the rear deck of an s13
i have some (6X9) and would like more info and pictures on it....MiddMackAttack wrote:How do you get 6x9's to fit in the rear deck of an s13
i have s13 hatch... i need some detail info on how to do it....benemorius wrote:I wouldn't know about a coupe, but a dremel to remove some metal will get them in a hatch. If you do it just right you can even still get the plastic covers back on and have it look stock. Sorry no pics.
its no prob with a coupe i used a grinder tin snips and a dremel they look pretty tight.benemorius wrote:I wouldn't know about a coupe, but a dremel to remove some metal will get them in a hatch. If you do it just right you can even still get the plastic covers back on and have it look stock. Sorry no pics.
Probably does sound like ****.xckid wrote:^^^ hey do those 6x9 rattle the cover when you turn it up or does it sound like your car is falling apart ..that is what i was thinking of doing....
I'm not into the whole sound system stuff, just wanted something better than stock. My brother works at Best Buy so I just got the 2nd Most expensive one they had their "Alpine Type R" the most expensive was the "Alpine Type R Composite". I have the 6.5" Type R's in the Front and the Type R 6x9 in the rear as you can see. I got the fronts for $77 and rears for $ 84 thats employee discount they are normally $160+ each set.xckid wrote:Those the alpine Type R... How do they sound..those are the ones i would like to get
