robomatic12 »
https://forums.nicoclub.com/robomatic12-u138186.html
Sun Apr 24, 2011 10:54 pm
Might I ask how you have figured out that the 6th cylinder is not firing?
What did you replace the injector with...oem nissan new or used? Use a multimeter to check the resistance between 2 terminals... should be around 11-13ohms.
What spark plugs are you using? These engines are picky about the plugs, they will run with anything somewhat correct but you can get problems down the line with hesitation if your using the wrong plugs.
Do you have the series 1 or series 2 PTU. PTU is located on the left side timing belt cover if your looking at the engine. The old version has a metal heatsink on it, new one just looks plastic.
Check all connectors especially for injector, coilpack, ptu, cas for corrosion and clean.
