Hmmm... Who did the fluid changes? The dealer or someone else?adren77 wrote:So about 2 weeks ago, I had a transmission/diff oil change. After that it got really cold outside, and since then I noticed some whining noise coming from the transmission.
This noise only happens in the morning when the car has completely cooled down over night. After the car reaches speed ~30 mph, the noise starts. The sound is very distinct and difficult to describe. At first I thought it was "wind noise" as if my window was slightly opened. After about 5 mins of driving the car warms up enough and the noise goes away.
This is my first winter in the car so I don't know if the car was making this noise before the transmission oil change, since I didn't get to drive it in such cold weather.
Anybody else experience a similar problem? I am wondering if this has anything to do with the service performed on my car, or if this is normal. Should I take my car in and have them check it out? My car still has powertrain warranty so would they charge me to examine the problem?
Thanks in advance!
adren77adren77 wrote:My friend is a tech at Nissan, so I have all my maintenance done there cuz I get hooked up.
Well your experience coinsides with mine. Changing transmission or differential fluid every 30k miles as recomended is IMHO a bunch of BSadren77 wrote:telcoman,
I asked on this board how often should it be changed, and people said every 30k miles. I just wanted to do the "proper" maintenance. I figured something as simple as fluid change can't hurt the car.
I've driven my last manual trans nissan for 200k miles with a single trans fluid change at 100k miles, and had the car not rusted away, I'd still be driving it.
I didn't want my Infiniti tech telling me: "Your car isn't covered by warranty because you failed to do minimum recommended maintenance."
Joe,
The guy that changed my fluid has done it 100 times on other nissans, and 350z's which probably have the exact same procedure. I find it unlikely that he missed something, though it's always possible.
It will be very difficult to get to a dealership to have my problem examined. By the time I get there, the noise will surely go away because the trans will be sufficiently warmed up. Unless I leave the car with them over night.
Thanks everyone for their input.
