It seems to me that since there is a problem that if it is contamination then it may be wise to possibly disassemble the master and slaves and clean/rebuild them. I haven't looked at the Infiniti to see what this involves, even if possible for the end user (sealed?) but have seen this as a suggestion since a flush can easily not get all the contamination. On previous cars I have owned this was relatively easy at least for the slave and not all that difficult for many masters.tollboothwilley wrote:I think I saw the same website with the covette clutch fluid change where he just suctioned out the amount in the reservoir and replaced it with new fluid right?
The clutch bleeding took a lot of time when I did the full fluid swap, but it was worth it.
What kind of brake fluid did you use...and I wonder if it will change the pedal feel by using a better brake fluid in the clutch line.
Clutch has been great so far. I only did 2 quick refills while the wife was feeding our son. I'm not sure if the problem is completely solved just yet, but we'll see - temperature is hitting triple digitsBrandAidDesignG35 wrote:I am an owner of an auto, but will stay tuned to see how this turns out, you're always finding something of interest
How is the clutch behaving now? Is it only when in stop n go traffic? Are you using synthetic fluid or are you using some kind of Nissan fluid? Keep us posted.
Yeah, he sucks out the fluid in the resevoir, replaces it, then pumps the clutch a couple dozen times, then repeats. Full bleed with pics to come.tollboothwilley wrote:I think I saw the same website with the covette clutch fluid change where he just suctioned out the amount in the reservoir and replaced it with new fluid right?
With a full garage, I might take on the challenge, but I'm limited right now. Damn housing investors keep outbidding my wife and I on homes (which would include a lift and full garage )pfarmer wrote:
Perry
Perry
I've experienced the sticking clutch pedal problem a few times in very hot weather. It usually occurs at the end of my 50 mile commute home on hot afternoons with the temp in the high 80's to mid 90's.Pauls98SE wrote:I was experiencing the clutch pedal sticking at about 1-2 inches before the top. Went back and forth with the dealer about what it was. I kept telling them it was contaminated fluid and needed changing. They said bad clutch, I took 2 different techs for rides and they agreed nothing was wrong with clutch. They still could not get it through their thick heads that the clutch fluid needed replacing. Of course problem only occurred when temp was above 80. Finally told them to forget it and I replaced my clutch fluid using the syringe method as described on rangeracceleration.com. No more sticking clutch pedal. That was 2 months ago and everything is good.
Definitely recommend doing this.
No. Original clutch line to my knowledge. I don't see how contaminated fluid with a low boiling point has anything to do with a SS line. What's the correlation?joe603 wrote:SBD, did they replace your clutch line with a stainless steel line? My OEM clutch would do that if I rev'd past 5k and dropped the clutch (a hard launch or burnout). Changing the clutch fluid would help...but only temporarily. (I did the syringe method...)
The only fix was the aftermarket clutch/flywheel install.
Blah blah blah blah. I just hit 70k and the car is on it's 3rd hehehe.telcoman wrote:
BTW I've got 91k miles on my original clutch
Telcoman
That is cuz you drive like an old mantelcoman wrote:BTW I've got 91k miles on my original clutch
Telcoman
Does a section of the clutch line pass close to the exhaust? If so maybe a shield is in order.telcoman wrote:
The pedal has never stuck to the floor. It only does not come all the way up so I just put my left foot under it to raise it the rest of the way up.
It clears up as the vehicle cools off. It has never occurred in the morning.
I'm going to take my fluids temperature the next time it happens.
Telcoman
