6MT cross reference
NewToVersa
Want to know if the 6MT in the versa is the same as the one in the sentra spec-V. Or were is it found in other Nissan's...
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
It will not be the same transmission as the spec-V. That 6-speed is actually from the Altima (since those two cars share the QR25).
The V's 6-speed was new (to the US market) for 2007. The only car that can possibly share the same transmission (and I can't even confirm this part is true) is the 2007+ 2.0L Sentra (since both are MR series engines).
NewToVersa
So there is one for the 2.5 altima, 3.5 v6 ( g35, 350z...), one for sentra 2.0 and versa...
Ever Victorious
'73 AMC Hornet
You might want to ask in the Altima forum if the manuals are the same between their 4 and 6 cylinder models, I do not know the answer to that.
NewToVersa
Can you at least confirm me that is as an LSD. Because i've seen a video of a burnout...
irsa76
Car: 1981 720 kingcab flatbed
No factory LSD for the Versa. The Australian media mentioned the Tiida(Versa) is related to the Renault Megane and implied they share a number of components. If this is true then I belive Quaife has a LSD that fits.
scott@westcovinanissan
Car: 2007 C11X 6sp
The 6MT for the 2.0 Sentra is different then the Versa's. But a few things the 2.0 Sentra and the Versa have in common are cylinder head, cylinder block, camshafts (both intake and exhaust), Flywheel (MT), Clutch Disc, and Clutch Cover. Just to name a few. Hope this helps.
~Scott
NewToVersa
Neo Xian Wu
Car: 08 Nissan Versa S Hatchback 6spd
so does that mean when the sentra gets lightweight flywheels, etc etc (assuming the V doesn't get them anytime soon) we can swap in parts from the 2.0 6MT?
Car: 2007 C11X 6sp
According to Nissan the part #'s for the clutch and flywheel are the same.. so I do not know for sure but after market clutch and flywheels should fit.
~Scott
ianh
Car: 2018 Nissan Pathfinder SL Midnight Edition
2003 Nissan Pathfinder
1997 Nissan 200SX SE-R
So what parts would be required to convert the 1.8 MR to a 2.0 MR engine?thanks
Ever Victorious
'73 AMC Hornet
An MR20, an ECU, and custom wiring more than likely
