This is Darius Foward mount manifold, I don't think the maf placement is a issue.MATTs14 wrote:Ok well im pondering what type manifold i should get. I definitely want the divided collector and the t3 but im not sure if i should get the forward facing or the center. Is it hard to keep your maf if you have the forward facing and is it too hard to run a downpipe with the center manifold?
It fits but you can see that I had to remove the stock coolant reservoir, find a new tank that fit and then ghetto rig up an overflow line from the radiator.eh? wrote:This is Darius Foward mount manifold, I don't think the maf placement is a issue.
Or go with a map system and the hell with the air filter j/kBut seriously the reason I went with forward placement if because of W/g and turbine clearance to the master cylinder. How much clearance do you have with the wastegate?Darius wrote:
Also with that setup, an Apexi filter is almost 100% necessary because other filters may not smooth the intake flow enough for the MAF to work properly. I'd recommend the center positioned unless you're having a huge turbo with 4-inch piping after the turbo.
heh yeah and spend another $1000 on a d-jetro PFC or entirely different EMS.eh? wrote:Or go with a map system and the hell with the air filter j/kBut seriously the reason I went with forward placement if because of W/g and turbine clearance to the master cylinder. How much clearance do you have with the wastegate?
As long as the 90s are mandrel 3-inch or larger, they will be plenty big for any of our power goals.MATTs14 wrote:will 90's in the downpipe really hurt performance that much though?
I'll add you to this list, I can't imagine shipping being that much more to Canada. I'll send an email to you.StyleP wrote:Is it too late to add more people? And do you think he'll ship to Canada? (I don't mind paying a little extra for shipping)
Ok sent you an email, let me know if you got it. Just waiting on you and we could finally get this baby rollingStyleP wrote:Is it too late to add more people? And do you think he'll ship to Canada? (I don't mind paying a little extra for shipping)
If so, I'll go with Forward mount twin scroll, t3 flanged, Single gated manifold. I can't pass up on an offer like this.
email: gegolick(at)ualberta(dot)ca -> just shoot me an email with the info
I can pay the deposit as soon as I get the paypal account to send it to (cause I know you want to do this asap).
