665whp stock bottom end
USDMSTALKER
Car: MY CAR
665 whp
not mine but a local shop
http://www.hybridynamics.com/
myees13
Car: 90 s13 coupe
was this ^ meant for the RB forum?
vutony
was an rb, swapped bak to sr for an event
Rookieca18det
Car: 93 hatchback (ca18det)
Rb was taking out due to rod bearing damage and a sr was swapped in for an event. The sr had the same setup that he used before to run a 10 sec pass, he took the car to the dyno and a hose for the wastgate blew off and boost spiked to 40psi =665whp on sr. Thats just what i got from skimming through it.
myees13
Car: 90 s13 coupe
lol I just looked at the pics and Ill I saw were RBs
Rookieca18det wrote:Rb was taking out due to rod bearing damage and a sr was swapped in for an event. The sr had the same setup that he used before to run a 10 sec pass, he took the car to the dyno and a hose for the wastgate blew off and boost spiked to 40psi =665whp on sr. Thats just what i got from skimming through it.
ETTInnov04
Car: 1989 Nissan 240sx fastback
Yea I'm not sure you can proclaim this as a 665 rwhp stock bottom end as it did this via the wastegate gate hose blowing off. It did it once for a second until he realized something was wrong. It was more of an accident. Even still... it did it.
