650cc deatchwerks injectors to small???
solow240
Car: 91 240sx s13
Ok guys my s13 redtop came with brand new 650cc deatchwerks injectors and im just wandering if they will be large enough for a gt2871 / .86...????
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Go 740cc. With a good tune you will have no drivability issues and get near 30mpg if you drive conservative.
solow240
Car: 91 240sx s13
Sorry it will be a gt2871r .64 for now, should i still go 740cc injectors??
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
It's better to have more head room with bigger injectors if you can get them tuned.
What will you be tuning with?
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
The following are for pump gas. You can run higher HP numbers with these sizes if you use race gas.
550cc-good to ~300whp 650cc-good to ~350whp740cc-good to ~400whp
So yes, I'd go with the 740's and a good ROM tune.
DrifterProdigy85
Injectors and Power is based alot of fuel pressure. 740cc and 43psi fuel pressure will max around 450whp. Bump it up to 50psi and they flow almost enough for 500whp. 650cc will flow enough for 400whp on stock pressure.
nzmoman
Car: 240sx 2 of em' and always lookin for more
^^^I have to agree with ^^^^ him. you could go bigger, but you dont need to for the 2871r. How much power are you trying to make and what is the car going to be used for? Those are things you should include to get better help from people.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
yep 740s are a good way to go. that is waht i am running wiht my .64
solow240
Car: 91 240sx s13
Well the car is mostly a street car weekend race car, mostly drag raceing at the motor is built, heres the info on the build
red top sr20det cp 86.5 8.5x1 pistonseagle h beam rodsacl race bearingsall arp fasteners, main studs, head studs, rod boltsapexi 1.5mm headgasketbrian crower 264 stage 2 cams brian crower valve springs & retainers greddy intake manifold light head workgt2871r .64 turbo MR header, elbow, downpipe and apexi n1 catback all 3" act street lite flywheel and some other small stuff looking to put down around 400rwhp
wzntha
Solow240sx
Car: sr20 powered 91 240sx
Ok guys im just going to sell the 650's and get some 740's so i don't have to worry about it later..
