65 410 distributor
The quirky and versatile Datsun 410 and 411 series sedans and wagons laid the groundwork for the 510.
Matzaraji21
Car: 1965 Datsun 410 Wagon, original 1189cc engine
2003 Chevrolet Silverado LS 1500 (doesn't really matter here)
does any one by any chance have a hitachi distributor for a 1965 410 engine E-1 1189cc????? thanks!!
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
Hey, Hey, Matzara21,
Welcome Aboard. So you have a 410 Bluebird with the E-1, wow :dblthumb: . That's my next Datsun!
What exactly do you need? The complete distributor or just parts?
Also I might have a more permanent solution over the Hitachi if you are up some trial and error. I promise, no modification.
I know we would all love to see some pics.
cheers,
Li'l Truckie
Matzaraji21
I need the entire distributor. I'll post some pictures in a bit. What else you got? Thanks
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Matzaraji21,
Okay, in that case you might be interested in this from eBay
http://www.ebay.com/itm/4-cyl-HS25D4-El ... 2d&vxp=mtr
or either one of these distributors from Victoria British -
http://www.victoriabritish.com/icatalog ... px?Page=29
As I say this is a more permanent and modern day solution over the Hitachi D-406 with a ready supply of parts. The MGA distributor should work and if you are interested let me know. I need to run down to VB and pick up some brushes for my generator. I'll pull a distributor and take it with me, take pics, and get the spec to see if it works while I'm there.
If its a direct match on the overall specs I'm going to get the Lucas style distributor with electronic ignition and give it a try. If spec are good and it doesn't work, I have an outlet to off load this with an English car nut, so I'm not out any money.
Let me know and I'll run this to ground, might be a day or two but I'll have you an answer this weekend.
Li'l truckie
Return to “Datsun 410 / 411”
