620 vs 240z water pump pully
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
hawaii_620
Car: 75 Datsun 620
Does anyone know if the water pump pully (assembly with fan clutch) is the same as the 240z-280z?
I have a broken fan blade on my 620 and I can't find a replacement fan. But ebay seems to have tons of 240z fan blades, so I bought one. But then I found out that the mounting holes don't align. So I was wonder, if I change out my whole water pump assembly, fan clutch and all, if the alignment of the pully is the same as the 620. Someone told me that the belt groves not match up. I'd rather ask questions first before pulling of the parts and buying new parts, just to find out that my solution wasn't going to work in the first place.
Thanks
-k
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Lots of parts from the L series engines were swappable. I would imagine the water pumps would be swappable across the entire L series family.
Return to “Datsun 620”
