M35SFIREMEDIC »
https://forums.nicoclub.com/m35sfiremedic-u194358.html
Thu Jun 07, 2012 8:55 pm
I just had my 60k done on my m35s. I paid about $400, but I had a few items done before the service before to soften the blow.
Transmission service, in-cabin filter and I dropped the k&n air filter myself, but here is the full list:
30k,60k,90k or 24mo. all wheel drives about $200 bucks more. sorry. In Mphs Tn $870, m35x $1,056. Hopefully in ATL the prices are not this steep.
Full list, I assume M35 and M45 services are similar.
Replace engine oil and filter
Lubricate all locks/hinges
Service transmission
Replace differential oil, engine air filter, engine coolant/flush system, in-cabin microfilter, engine drive belts, radiator cap, wiper blade refills
Rotate and balance tires
and inspect the following:
All lights, axle and suspension parts, brake lines and cables, brake calipers,pads, rotors, cruise control vaccume hoses, drive shaft boots, exhaust sys, front suspension ball joints, fuel lines/connections, fuel tank vapor vent sys hoses, headlights adjust if necessary,steering gear and linkage,and steering linkage ball joints.
hope this helps.
