Engine Built by: Dee(Boost_boy) Thank u sir!
PICS Coming Soon!
http://www.youtube.com/watch?v=SPn-EQSa ... e=youtu.be
I'll share you with you my part in this. By the way, "G" love the video, absolutely adore the car and it's cleanliness, and definitely thanks for the "shot-out".Sideways s12 wrote:What all did he do and how much did it run you if you don't mind I may be getting a spare det and was considering sending it him to have built but would like some details....
float_6969 wrote:Looks good, but as I posted on the video, you've got some on-boost surge there that's VERY bad. From your video I said,
Agree'd. It was the first thing I noticed. That's REALLY hard on the turbo. If you have an electronic boost controller, you need to turn the gain down a little so the boost ramps up a little more slowly. If you're just on a wastegate spring, your turbine housing is too small and you need to bump it up a size.
Long story short, the turbo is spinning too fast, too soon.
Also, what intake manifold is that?
Well said Dee! Thanx for the MONSTER build and I look forward to making more power and rolling out with u when you bring your machine out!boost_boy wrote:I'll share you with you my part in this. By the way, "G" love the video, absolutely adore the car and it's cleanliness, and definitely thanks for the "shot-out".Sideways s12 wrote:What all did he do and how much did it run you if you don't mind I may be getting a spare det and was considering sending it him to have built but would like some details....
Let's start with the cylinder head = JUN cams, valve springs, standard retainers, etc. I did the port and polish as well as modified the head so that the camshafts will not be interfered with by the head. The valve job was done by REV valves and those aftermarket pieces with titanium involved (I believe). If he wants to share with you the specs of his camshafts he can. I bleieve they are a 272*, but I forgot the lift, so he can fill in the blanks if he choses to.
Bottom end = (Re-Used) CP standard 83mm pistons and fresh CP rings, New Crower Rods, new main and rod bearings, crank was meticulously polished by me, honing done by me, rotational assembly balanced professionally, but assembled by me. This is a continuation of an engine that was built years ago when he just wanted 400whp and that was easy. The kid is hungry and want more and now he knows that this stuff costs and the cheap way to the promise land usually yields failures. He hasn't cheaped-out, but he's aware of what happens when you do. You got to spend to win/achieve, so plan accordingly.
Tuning was not done by me on this particular set-up, but congratulations to the shop that tuned it and I'm glad "Overboosted180" is achieving his objectives. Keep on boostin' it "G"
Precision 6766 ball bearingSideways s12 wrote:not bad what size turb are you running? And Boost Boy you has pm sir
Stock ca18 5spd transmission and next Dyno session we will be using e85 and turning the boost up!tommey wrote:What gearbox are you running?
Any plans for another fuel?
tommey wrote:So you are passing the 1000 hp mark with a stock gearbox?
Nice
Why did you choose the 6766 over the 6466?
Im looking forward to see some more progress on this car!OverBoosted180 wrote:tommey wrote:So you are passing the 1000 hp mark with a stock gearbox?
Nice
Thanks! and there's no big reason on the 67 over the 64, just wanted to try a slightly larger compressor wheel to gain the power that I am aiming for. so far it's doing the job seeing that this is the first dyno session this car has seen with this freshly new set-up...i will use the stock ca18 transmission until it it's maxed and cannot hold anymore...The car drives like a dream coming from a 1.8l and I have seen several big powered sr's and ka's but this engine IS just a step under the RB. My boy Nigel at Premiere builds 1000whp RB's all day but when he saw the potential and similarities in it, he instantly became a believer in it and is willing to help me make unbelievable power with this motor, along with the support of the ultimate CA18 builder himself, Dee aka boost_boy!
tommey wrote:Im looking forward to see some more progress on this car!
What exhaust housing are you running and when are you hitting boost?
tommey wrote:I hope you have a fuel system to support that 3+ bar recipe!
