Ba11erz »
https://forums.nicoclub.com/ba11erz-u123579.html
Thu Aug 05, 2010 10:14 am
600whp is just under doubling the stock HP configuration. I don't believe it was the intentions of the Nissan engineers when they began to architech the VG30/VG30DETT motor to withstand nearly double the base HP configuration. That would be taking a huge risk and doesn't quite pass the common sense test. I'm not to say it can't be accomplished though. Sure, anything is possible. However, it wouldn't be smart nor 'safe' as WhiTTe Z pointed out, and you may risk bodily injury. If you [do] decide to go that route, then best of luck. But there's something about I told you so that has purpose.
Be sure to document everything. Especially the advantages & disadvantages so other ppl can read and learn from your experience.
