DarkStar wrote:574-240sx: About how much did your swap cost you? I'm planning on doing one..
Ok prices on the auto to manual conversion. It cost about 300 plus when it was all over. I sold my good auto for 100 locally. I also cut the brake petal to save time and money. Looks just like a manual brake petal. It also took a full day to complete and a extra hour to bleed the system a couple times and to adjust the clutch.
250 - junkyard transmission, pressure plate, flywheel, manual drive shaft, clutch petal, rubber brake cover, hydro clutch line, used slave, used master, shift boot and cosmetic plastic piece. 30 - resurface flywheel and lighten a little20 - new clutch disc60 - new pressure plate10 - kit to rebuild clutch master20 - misc supplies and fluids20 - new slave cylinder
